727 owners please reply.........
Old Apr 25, 2005 | 11:50 AM
DollarBillz's Avatar
Default 727 owners please reply.........
yes day and night go with someone that has been building that motor for year's now craycraft or kenz it's worth every penny more
Old Apr 25, 2005 | 01:22 PM
RaptorOwner's Avatar
Yes, I can vouch for Craycraft, I heard Kenz is good too.
Old Apr 25, 2005 | 03:19 PM
Rider1169's Avatar
So i should have them port it? I plan on doing the bore at a local shop, and getting a good piston and installing it myself.
Old Apr 25, 2005 | 08:54 PM
RAPTORAZ's Avatar
Originally posted by: Rider1169
But is it a lot better to just have the big names do it?
Depends on how much power you want it to have. The cylinder head porting is the key. Someone unfamiliar with a Raptor's head flow characteristics won't do as near as good of a job as someone that is. It's not just as simple as opening up the ports. Mine have been thoroughly reshaped. Which includes actually adding material. As well as removing it.
Old Apr 25, 2005 | 09:41 PM
  #15
Rider1169's Avatar
Ahh, i got ya. Well i guess ill be giving Kenz a call to get a estimate for the price and all. Thanks for the replies guys---Rider1169
Old Apr 26, 2005 | 12:33 AM
  #16
BigScary's Avatar
i'd bypass hot cams all together.......
I've had a couple break.....and they are also very mild......both of them...if you are going to a 105mm bore....you'll have NO shortage of bottom end power regardless what cam you run.......I had a 685 web with my 740 and that thing pulled like a tractor
Old Apr 26, 2005 | 01:11 AM
  #17
derbyking's Avatar
i would go with a 686 if i just wanted a fast trail bike.the only thing youll miss is a thinner wallet.i dont think the 727 is worth the extra cash in a mild build,ive built both with basicly the same set up,porting,stage2 cam,12-1 piston,ect
Old Apr 26, 2005 | 03:45 AM
  #18
maddog56's Avatar
IMO if you are going to tear into it and split the cases for a rod install there is no reason not to machine the cases and get the sleeve put in regardless of whether you are going to go to 105mm or anything smaller. Might as well do it while you're in there, costs a lot more to do it twice.
Old Apr 26, 2005 | 09:38 AM
  #19
Rider1169's Avatar
Yea, id rather do it all one shot. Im going with LA SLEEVE for the 727 sleeve, and then looking around still for a piston. Like i said, ill probably get ahold of Kenz, or Craycraft, or anyother big builder to see what kind of pistons they carry and all about the porting. I had given LA SLEEVE a call, and the only 105mm piston they carry is a 12.1:1 piston. As far as my knowledge carries me, i thought about 11:1 is as high of compression you can go on 93 octane fuel. Anything higher needs 100+ fuel?
Im still debating on the camshaft also. Where can you buy webcams at for a decent price?---Rider1169
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
