problem with carb of atv YFZ 450
Old Apr 26, 2005 | 10:24 PM
Marauder's Avatar
Default problem with carb of atv YFZ 450
given the application for which I am using the 450, I had to eliminate the airbox and apply an air filter right at the openning of the carburator. the engine is running very lean and I havent changed the settings of the carb until I can get some advice on how to set it up to run a bit more rich. thanks guys.
Old Apr 26, 2005 | 11:12 PM
buck183's Avatar
What kind of filter? Are you running an aftermarket pipe? If so, which one? What is your elevation?
All of these things will make a big difference in jetting.
Buck
Old Apr 26, 2005 | 11:19 PM
drgnerth's Avatar
What kind of filter do you have that will bolt directly to the carb? I didn't think that any would work due to the shock.
Old Apr 26, 2005 | 11:58 PM
buck183's Avatar
ESR and Ron Woods both make one that bolts directly to the carb.
Buck
Old Apr 27, 2005 | 12:02 AM
Ernie660R's Avatar
48 to 50pj and 172 thru 178mj
This should put you in the ball park....
Old Apr 27, 2005 | 04:39 AM
yfz450trx400ex's Avatar
Buck, are those two filter's any good? Compared to the adapter that makes the clamp on K and N usable? (Do you know which one I mean? I can't remember the brand, but I believe that it's the most common one. At least the most common that I see) That air tube from the carp to the box seems that it may be pretty restrictive, so I'm wondering if the filter bolting strait to the carb may be better. But I also ride in some mud/dirt sometimes, so would that pose a problem without the box blocking most of that?
Old Apr 27, 2005 | 09:43 AM
buck183's Avatar
A lot of guys run those two brands of intakes. They are probably more common in the dunes or at the MX track. I do see a couple of guys running them on trails here and there.
They are good products. I don't feel like they are fit for my riding style due to the amount of mud and dust I get into. But to each his own.
Go spend some time over at y f z central.com and you will see several threads on those two intakes. Very popular over there.
Buck
Old Apr 27, 2005 | 12:11 PM
I'll do that, thanks.
Ty Speece
Jul 2, 2015 04:59 PM
joshuafromny
Jun 22, 2015 05:30 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
