02 Warrior no spark....please help
Old May 13, 2005 | 08:28 PM
SandZilla's Avatar
Default 02 Warrior no spark....please help
I have a 02 warrior that is not getting any spark. I changed out the coil and put in a brand new stator and still nothing. I have went through all the wire connections and still nothing. Please help.
Old May 13, 2005 | 11:45 PM
TRLYFZ450's Avatar
Have the CDI box checked out. It sounds like you haved checked everything else. Good luck..
Old May 14, 2005 | 02:22 AM
SandZilla's Avatar
I have a 99 wolverine and I tried the cdi box from that and but no dice, the two have the same part #.
Old May 14, 2005 | 12:03 PM
hondabuster's Avatar
Have you checked the kill switch? fuses? main switch works correctly?Tried a new spark plug? Checked the spark plug cap resistance? It should be 10k ohms.
Old May 18, 2005 | 06:01 PM
SandZilla's Avatar
yup, I checked all that twice, I am ready to stick a road flare in the tank.
Old May 18, 2005 | 06:46 PM
Warrior350CR's Avatar
Sandzilla,
Just to confirm, you changed the primary coil (stator), pickup coil (part of stator assembly) and the ignition coil (front of quad) ?
Make sure the connectors at the ignition coil are clean, you should get about 30volts DC at the ignition coil with ignition on. while measuring the ignition coil voltage, turn the KILL switch from run to off and be sure the voltage changes to 0 to confirm the kill switch works.
Old May 23, 2005 | 11:02 AM
SandZilla's Avatar
Yes I installed a new primary coil and pickup coil. I took the ignition coil from my wolverine and tried it on the warrior instead of buying a new one. So with the ignition turned on I should have 30 volts at the orange wire on the coil?
Old May 23, 2005 | 01:36 PM
Quadder79's Avatar
I had the same issus twice in the past year on my 98 warrior. The first time i swapped out the stator/pickup coil. 6 mths later, no spark again and I just replaced the pickup coil AGAIN! Where did you buy your stator from?
Old May 23, 2005 | 06:27 PM
SandZilla's Avatar
I bought the new one from ricky stator, I never got any spark after I put the new one in.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
