Warrior Top End Rebuild?
Old Oct 5, 2000 | 09:57 PM
PC_350_Warrior's Avatar
Ok, I have a 1996 Warrior and am going to rebuild the top end soon (piston, rings, circlip, bearings...etc..) And have a couple questions. #1-can I take off the cylinder and do the rebuild while the engine is still in the frame?
#2-how should I break it in? I've never broken in a 4 stroke..only 2 strokes. Thanx for any replies!
Old Oct 5, 2000 | 11:18 PM
54warrior's Avatar
It can probably be done while in the frame, but you will have a whole lot more room to work if it is out of the frame. As far as breaking it in, go easy at first, break it in slowly.
If you really want some high performance out of the warrior motor, pick up a kodiak 400 cylinder, it bolts right up,you can even have some bottom end work done and then it can be bored out to about 500cc. another big improvement would be carb, cam,and a larger intake valve with heavy duty springs.
these are just suggestions, good luck
Old Oct 6, 2000 | 08:33 AM
lucey's Avatar
You can easily rebuild the top end, while it is in the frame. If you ever have any questions, just give me an email. I just finished a complete engine in a 1997 Warrior.
Old Oct 6, 2000 | 11:14 PM
YZ250WR's Avatar
54warrior, have you done that before.. using the kodiak cylinder on a warrior?? what year warrior will it work on. i know most compontes on all the warriors are the same but i know there are some minor changes as well between years.. i am looking to get a warrior my self and would like to bring it to a 400 or so without going 60/over on a bore.
just curious, would i need the valvecover rockers and valaves, ect.. for the kodiak as well?? or does the rest of the warrior parts just bolt in?
thanks
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
