banshee resleeve one cylinder?
Old May 26, 2005 | 08:19 AM
superevil's Avatar
Default banshee resleeve one cylinder?
Our 2001 banshee seized and ruined the left cylinder sleeve(cracked bad).It was on its original bore. My mechanic is telling me i can get away with resleeving just the left cylinder,and then boring both cylinders to 20 over. Is this guy right? or am i taking a big risk? it will be resleeved by la. sleeve,with a standard banshee sleeve.
Old May 26, 2005 | 08:29 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I dont see a problem with it at all. There is no need to re sleeve-both cylinders if only one is damaged.
Old May 26, 2005 | 04:36 PM
TooFast2Pass's Avatar
Yeah, the tech is right. One cylinder can be resleeved and it will run great. LA Sleeve does good work and you'll have nothing to worry about.
Old May 26, 2005 | 10:02 PM
untouchable350's Avatar
No risk at all by doing this, both your cylinders will be refreshed with same compression rate
Old May 26, 2005 | 10:55 PM
NastyNate03's Avatar
yup i w ould go with one new sleeve like already said
Old May 28, 2005 | 03:52 AM
superevil's Avatar
thanks,for some reason i though that maybe the new sleeve would be slightly diferent
thanks for the replies
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
