another block off plate problem/question
Old May 27, 2005 | 03:04 PM
FoxForma's Avatar
Default another block off plate problem/question
After i installed my block off plate for my warrior whenever I go to use the back brakes as soon as pressure builds up it will leak the fluid out of where the plate bolts onto the caliper. It comes out right where the plate is bolted in, possible i have the plate backwards or something? Is the plate suppose to seal up in that spot or is there something else wrong inside the caliper that is letting it leak out and cause the brakes to not be able to build full line pressure? hope someone can help. thanx
Old May 28, 2005 | 01:45 AM
NastyNate03's Avatar
not sure but i think they have a gasket between the block off plate and caliper but im not positive
Old May 28, 2005 | 02:14 PM
lethaface's Avatar
Your right nate there is a gasket..I'm not really sure if the gasket is to keep the fluid in or to keep the junk out..I used the block off plate on mine with no flaw's but my little bro's warrior did the same thing your's is doing..Did you use the gasket from the old e-brake system? that could be your problem
Old May 28, 2005 | 02:45 PM
FoxForma's Avatar
there was no gasket from my old system. The gasket is for the dirt anyways. I was told that its the seal inside the caliper that is bad so i have to get a caliper seal set to fix it. Not a big deal i guess just annoying
ReconBayou
Oct 31, 2022 05:37 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
tysonbully
Sep 28, 2015 02:30 AM
nastyblaster100
Sep 13, 2015 01:19 PM
