is it bad to ride
Old May 29, 2005 | 11:55 AM
warriorboy22's Avatar
Default is it bad to ride
is it bad for the engine if u ride it when the vavles need adjustment????? and how long does it take to adjust them about????
Old May 29, 2005 | 01:04 PM
Doctorturbo's Avatar
GOT BOOST!
Depends if they are tight or loose. Loose, no. Tight yes. Even then, it depends on how tight. If you have them so tight it hangs the valve open, then yes, that's a really bad thing.
Depends on how good you are and how many things are in the way. Once you get the caps off, it should not take any more than about 1 minute (no adj) to 5 minutes to adjust the valve.
Old May 29, 2005 | 01:08 PM
thanks do u know by any chance what to adjust the warriors valves to????
Old May 29, 2005 | 03:23 PM
GOT BOOST!
Sorry I don't. I'm sure someone else will tell you soon.
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
