Warrior prob
Old Jun 4, 2005 | 05:41 PM
ZoomZoom14's Avatar
Default Warrior prob
My warrior is startin to act a lil funny. I'll go riding and for the first 5 minutes or so its fine full throddle and everything. A little bit after i get onto the trails it will jus cut off and wont run past half throttle and at half throttle it jus spits and sputters but lower it runs fine. ANyone know what the problem could be?
Old Jun 4, 2005 | 07:03 PM
1988fast250x's Avatar
you dont have the right jets in the carb or the carb is dirty!!
or you need a proformance air filter with the jets that sounds like the problem
you probably didn't change the jets with the pipe did you!!
its getting the right amount of fuel and air when your at a lower speed but not enouf when you give it some throtel
hope this helps
Old Jun 5, 2005 | 06:35 PM
ZoomZoom14's Avatar
Thnx. I bought the 4 wheeler from the dealership when a guy traded it with the pipe already on it so they may not have changed the jets. The thing is that Ive had it for months and its just now starting to act up.
Old Jun 5, 2005 | 07:10 PM
Pelphrey's Avatar
When you change the pipe is it required to change the jets? Or are there different settings for different pipes? Same goes with replacing the air filter?
Old Jun 5, 2005 | 08:08 PM
warriorboy22's Avatar
its required but with slipons you can get away with out jetting it but you should jet it
Old Jun 5, 2005 | 10:42 PM
if i were you go out and buy an air filter like a uni or k&n and put it on the bike you wont be sorry you did it and yes i think it is required that you change the jets for the different pipe i would call someone like mikuni or some high end carb place and tell them you need 2 know what jets 2 use with your slip on and the air filter and they will give you an idea on what to use!!!
and take the carb off and clean it with carb cleaner and get a rebuild kit for it!!
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
