whats a reed value?
Old Jun 4, 2005 | 11:39 PM
LatinoSalvatruco's Avatar
Default whats a reed value?
whats a reed value and were can i find one?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 5, 2005 | 12:08 AM
JakalWarrior's Avatar
Try google. If you dont have a two stroke forget about it.
Old Jun 5, 2005 | 12:09 AM
raptorider660's Avatar
yea its only for two strokes
Old Jun 5, 2005 | 12:12 AM
ok thanks
Old Jun 5, 2005 | 12:50 AM
Blastermaster's Avatar
while it is only for a two stroke, and judging by you`r "ok thanks" reply you have a 4-stroke, but to answere you question of what is a reed valve,
the reed vlave bolts to the intake of a 2-stroke cyl, the reeds are attaced to a reed block, (usually shaped like a triangle) which is the part that bolts to the cyl, but the basic job of the reed valve is when the piston is moveing up on compression stroke, it opens to allow the air/fuel mix from the carb into the crankcase, but when the piston is on its way back down the reeds close keeping the air/fuel mix from going back into the carb and forcing the mix that was in the crankcase through the ports and into the combustion chamber, which also forces the burned fuel out the exhaust port
Old Jun 5, 2005 | 12:53 AM
oh thanks
Old Jun 5, 2005 | 09:21 AM
enFORCER's Avatar
Hmmmm, could you be a little more "detailed" in your explanation
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 5, 2005 | 11:28 AM
heatseeker8's Avatar
Ask ehlitdew..he has an abundance of knowledge on two strokes..you and him sound like brothers...[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jun 6, 2005 | 11:50 PM
Originally posted by: enFORCER
Originally posted by: Blastermasterwhile it is only for a two stroke, and judging by you`r "ok thanks" reply you have a 4-stroke, but to answere you question of what is a reed valve, the reed vlave bolts to the intake of a 2-stroke cyl, the reeds are attaced to a reed block, (usually shaped like a triangle) which is the part that bolts to the cyl, but the basic job of the reed valve is when the piston is moveing up on compression stroke, it opens to allow the air/fuel mix from the carb into the crankcase, but when the piston is on its way back down the reeds close keeping the air/fuel mix from going back into the carb and forcing the mix that was in the crankcase through the ports and into the combustion chamber, which also forces the burned fuel out the exhaust port
Hmmmm, could you be a little more "detailed" in your explanation[img]i/expressions/face-icon-small-wink.gif[/img]
what would you like to be more detailed???
Old Jun 7, 2005 | 01:15 AM
Hippyhunter's Avatar
Thanks Blastermaster. I did not know what one did either. (non internal motor wrenching 4 stroke dude here)
QuadRiders
Oct 22, 2015 04:13 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
