yfz problems
Old Jun 10, 2005 | 08:45 PM
Eyetattoo's Avatar
Default yfz problems
Originally posted by: killakovach
Originally posted by: Hozed
Originally posted by: HughJazz
Try running it with the headlights on
that gets rid of sputtering?
i think not...
more than likely a jettng issue... if its lean... you will find it popping alot... mine sputters now because its getting warmer and i havent gone back to my summer jetting yet.
dont listen to this yahoo he doesnt know what hes talking about. i took mine to a yamaha dealer and the did everything they could think of and on day i was in a atv forum and someone suggested to drive with the lights on and i havent had any problems since.yamaha made it so running with your lights on keeps the electrical system charged thats why when your fan kicks on it doesnt drain your battery.
No offense but my 450 never sputters with the lights off. Sputtering in a jetting issue. Bump up your jets and the sputtering will stop and your bike will run much better.
Old Jun 10, 2005 | 08:52 PM
Hozed's Avatar
i think not...
this yahoo?
rofl... i KNOW im right... use ur head kid... hows does headlights effect ur carb? moron....
its jetted wrong... if it pops, try upping the main jet a size or 2.
my headlights were taken off my quad before the first ride... and the fan too. no sputtering... except when i needed to rejet.
Old Jun 10, 2005 | 09:00 PM
Eyetattoo's Avatar
i think not...
this yahoo?
Trust this guy he knows what he is talking about.
Old Jun 10, 2005 | 09:01 PM
Hozed's Avatar
ty sir.
Old Jun 10, 2005 | 09:29 PM
  #15
RacinJason's Avatar
Doing the Hokie-Pokie just before riding will keep you Yamaha from sputtering...you remember?...you put you left foot in...
if it starts to cause you any problems on the trail after the Hokie-Pokie ritual
lay flat on your stomach and pound your fists against the ground in opposition to you kicking feet screaming
WHY WHY did I listen to those monkeys...
BRAAAAP
Old Jun 10, 2005 | 09:38 PM
  #16
2strokesceamer's Avatar
it could be jetting but it can be the stock pipe because it is very stuffed up
Old Jun 12, 2005 | 10:23 PM
  #17
Playmaker's Avatar
Thanks for the input. I don't think it is a headlight issue....I always run mine with headlights on. I think you guys are right about it being a jetting issue.
Thanks
Old Jun 12, 2005 | 10:39 PM
  #18
Hozed's Avatar
even that is odd tho... you have no mods that would effect jetting...
maybe your carb needs to be cleaned out... tried that?
Old Jun 13, 2005 | 11:23 AM
  #19
Eyetattoo's Avatar
Even though he is stock the jetting is still lean from the factory plus he is near sea level which makes it more of an issue. Least now you have a starting point. Try different jets if that doesnt work clean out the carb.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
