Bearing Help Fast!
Old 06-09-2005, 12:09 PM
Jman68's Avatar
Default Bearing Help Fast!
Okay guys...I need a crank bearing for my 426 by friday. So far, no good. I am gonna be checking a few honda dealers today but its doubtful...
I have one question though...if I match it up at a bearing distributor place, should it be just as good as OEM? I figure itll always be under constant lubrication and it won't get dirty...I just need to know if I could trust one from a bearing place....I'm also going to see if my honda dealer can overnight one to me....I just need some opinions and some help here guys...most people reply a lot faster in the Yamaha forum thats why I posted it here.
Thanks!
-Justin
Old 06-09-2005, 05:35 PM
garrett5462's Avatar
well, if it is the same size and dimensions then i dont see why it wouldnt work. make sure you post how everything came out.
Old 06-09-2005, 05:49 PM
sixsixT's Avatar
You should be able to get one that's just as good as OEM from a bearing supply.
Old 06-09-2005, 05:57 PM
RacinJason's Avatar
be carefull those bearings take heavy loads and extreme heat...there are different qualities of bearings out there...the bearing pro's should be able to set you up with the right part
braaaap
Old 06-09-2005, 07:27 PM
Jman68's Avatar
Well, I was amazed. Call up a different honda dealer, and they ahd 2 of em in stock! I couldn't believe it. I took it out to my mechanic and told him where I got it and he thought I was joking! Thanks anyway tho guys! Gonna get the 426 back tomorrow....and go RIDING!! for the first time in a month since the rebuild!
-Justin
ReconBayou
10-31-2022 05:37 PM
exmotocrosser
09-13-2019 06:12 AM
Pehter
09-04-2016 08:22 PM
jbrewster94
09-23-2015 04:16 PM
MikeyBoyesq
09-22-2015 10:02 AM
Quick Reply: Bearing Help Fast!
