Big Bear Cold Starting ???
Old Oct 11, 2000 | 08:39 PM
TXRam's Avatar
I have a 2000 Big Bear 4X4. I love it - it has plenty of power and speed for what I use it for.
But when starting on a less than 75 degree day, I have to choke it. I'll be honest, I don't know alot about these small engines, but I am pretty mechanical. It hasn't been back in for the "normal" valve adjustment, etc. recommended by the dealer. I figured I would change the plug and am looking for a service manual as I would like to adjust the valves, set the idle, etc. myself.
Any advice or help is greatly appreciated!
Old Oct 12, 2000 | 10:57 PM
plunker's Avatar
Hi , also have a 2000 Big bear SE , almost always have to use the first stage on the choke and it is always fussy when cold. Set the valves myself at 800KMS 2 weeks ago,they were still within specs but at the high end so I set them at the tight end of the tolerance and it did quiet it some but the valves have always been louder then I thought they should be . Good Luck!!
Mkp
Mar 28, 2020 03:50 AM
buckshit
Sep 24, 2015 08:49 PM
Bulls
Jun 7, 2015 12:55 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
