Raptor valve clearance?
Old Oct 11, 2000 | 11:05 PM
pairof98s's Avatar
Anyone tried to adjust the valves on their Raptor? I don't want to leave my machine at the dealer because I know they all want to joy ride on it. They probably don't have the service manual anyway.
If anyone has the specs, please post the info.
Old Oct 12, 2000 | 01:22 AM
shollz's Avatar
I had mine adjusted on tuesday. It runs alot better now. My 1st and 3rd intake valves were way loose and the 2nd was tight. I did not take mine to a dealer because they are morons. I stripped the front plastic and took off the gas tank, then took it to a local cycle shop took him 15 minutes and he charged me 15 bucks.
I got these specs right off of the microfische for the raptor.
intake .10-.15mm
exhaust .15-.20 mm
when engine is cold!!!
Old Oct 12, 2000 | 09:42 AM
bash's Avatar
just curious, but could you describe "runs better"? I just wondered which part of the power range it helps.
Old Oct 12, 2000 | 12:49 PM
pairof98s's Avatar
Thanks for the specs. I am curious about the microfiche, though. Did that include parts also? I want a pair of the Raptor grips to put on my Banshee and I also need the correct oil filter. Can you get the part numbers?
Thanks,
Old Oct 12, 2000 | 03:58 PM
atvinstructor's Avatar
Oil filter part# is 5DM-13440-00-00.
I paid $11.99 for them but saw much higher $$ in here?
Old Oct 12, 2000 | 05:12 PM
Banzai's Avatar
Sholz, did you watch him do the adjustment? If so were there timing marks that he lined up? If not, do you know the crankshaft position when he checked clearances?
Banzai!!!!!!!!!!!!!
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 11, 2015 11:42 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
1ArmBandit
Sep 8, 2015 08:59 PM
