Kodiak Deep Water Test
Old Oct 18, 2000 | 12:26 PM
yam8's Avatar
Don't go over your back fenders on a 2001 because that is where the belt intake is i hear. My buddy did on the weekend and sucked in a pile of water. I went through on my 2000 grizz with no problems.
Just a pointer.
Old Oct 18, 2000 | 12:29 PM
FKNA's Avatar
Yam, the belt intake happens to be BOTH in the rear and the front. It's the front that normally gets me.
Old Oct 18, 2000 | 03:09 PM
yam8's Avatar
Actually the rear supposely is the one that inhales air and the front is the one that blows air out. You have to have 2 one to cool the air and one to release the air and the kodiak's is in a bad spot for deep water. Even the dealer told me that it could be in a better spot.
Old Oct 18, 2000 | 04:17 PM
FKNA's Avatar
Either way, BOTH ends lets water in. hahaha. I definitely will be making modifications to it to keep water out of the belt. I just haven't figured it all out yet on how I'm going to accomplish that.
Old Oct 18, 2000 | 05:07 PM
  #15
yam8's Avatar
No buddy, the front is like your exsaust pipe it pushes air out, so as long as you don't stall it your ok.
That is what the dealer told me. Ask yours.
Old Oct 18, 2000 | 05:51 PM
  #16
FKNA's Avatar
That very well may be true, but there certainly isn't enough "push" to keep the water out. The time that it becomes an issue (front or back) is when I lose forward momentum (even if it's for a moment), then the front will take on water real quick which in turn makes the belt slip, which in turn makes me lose more forward moment until it finally stalls on me. Someone has given me a good idea for the front. This weekend I'll be putting on a 2-3 inch snorkel "under" the rack and plastic. There are two drain plugs for the front, one high, one low. I plan on running a drain hose from the top plug. Hopefully (in theory) if I were to lose forward momentum outside of the snorkel should hold about a gallon of water and this might be just enough to buy me some time until forward momentum is regained and that water then drains the my drain hose. As I said, in theory it may work. I'll know for sure this weekend when I modify and then put it to the test.
Cantbuytime
Aug 17, 2015 06:33 PM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
RedRancher
Jul 10, 2015 06:36 PM
