flywheel help
Old Jul 30, 2005 | 01:07 AM
I40MXer's Avatar
Default flywheel help
what does a lightened flywheel do i know a heavier flywheel gives you smoother power
04 blaster
96 RM 125 (for sell great cond. $1200)
96 warrior
92 timberwolf
Old Jul 30, 2005 | 01:15 AM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
More likely to stall out, but it will help your bottom end a bit.
Old Jul 30, 2005 | 01:24 AM
YFZ660R's Avatar
If you also get a heavier flywheel it will increases inertia, which reduces the quad's tendency to stall out. It will reduce vibration which reduces rider fatigue. As you already know it gives you smoother power that pulls harder and harder, top end is not affected.
Old Jul 30, 2005 | 07:33 AM
enFORCER's Avatar
The engine will rev faster with a lightened flywheel and it will rev slower with a heavier flywheel.
I run a PVL ignition on my Banshee and it has no flywheel[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 30, 2005 | 08:39 AM
lethaface's Avatar
Depending upon what type of riding you do it is a nice little mod..It basically makes the motor spool up faster and rev back down quicker(great for MX..Your getting into the powerband faster with a lightened flywheel..You actually loose bottom end if you take a good chunk off the flywheel..I'm not sure about on other bike's but on my blaster your either giving it all or nothing..If you do have a blaster your flywheel is overly heavy..I had 8oz shaved off mine and i love it..But don't buy into some companies bull shiot..Any machine shop that has a lathe can do it..If your doing this mod on a blaster the weight is taken off the top off the flywheel(the flat side)..If you do decide to do it you need a flywheel puller and a flywheel holder to get the flywheel off..If your doing it on a blaster when you put it back on it needs to be torqued to 53ft lbs..Hope that helps
Letha
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
