'91 Big Bear - Back Bearings
Old Oct 23, 2000 | 01:56 PM
wtavcar's Avatar
I have a '91 Big Bear 350 4x4. My question is back break bearing replacement. I noticed some up-down play in the back wheel that houses the break drum. I naturally suspect the bearing are shot. I flipped through my HAYNES manual showing how to replace the bearings. The only problem I have is that the book explicitly says that some strange tool is required to lock-unlock the two nuts on the drive shaft. When I called a local dealer to ask for this key they told me that the tightening pressure welds the two nuts together. They simply take a chisel and break them and put two new ones.
Is this really necessary? From what I can see there is no way for the DIY to replace the bearings.
Can anyone shed some light?
I asked for the price of all the necessary to change in innerds (seals, O-rings, bearings, etc.) and get a price of 200 (parts only). Does this price make any sense for a couple of bearings and some gaskets ?
Thanks
Old Oct 23, 2000 | 08:07 PM
wgr's Avatar
wgr
Dennis Kirk sells the wrenches for the axle nuts.
Old Oct 24, 2000 | 09:21 AM
wtavcar's Avatar
Thanks for the info. Who/what is Dennis Kirk? Can I get this in Montreal?
Thanks
Old Oct 24, 2000 | 07:46 PM
wgr's Avatar
wgr
Yes you can, it is in Minnesota i will find the phone number.
Old Oct 25, 2000 | 06:18 AM
Bushbunny's Avatar
Howdy...once you get it apart and have the bearings and seals out...take them to your local bearing retailer and see if he can match some up...they will be cheaper then buying them from the dealer ..
BB
Old Oct 25, 2000 | 08:37 AM
Harold's Avatar
don't buy your bearings from dennis kirk unless you have the industry standard number, their catalog will probably be wrong!!!!!!!
Old Oct 25, 2000 | 11:07 AM
wgr's Avatar
wgr
Phone # 1-800-328-9280 my catalog part # for the axle wrenches is 28-813,verify the part# is correct before you order.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bikedad3
Jul 2, 2015 02:15 AM
bonanza 440
Jun 26, 2015 10:01 PM
volsgo30
Jun 4, 2015 06:07 PM
