valves
Old Sep 18, 2005 | 09:56 PM
raptorider660's Avatar
Default valves
i just my adjusted my valves and i dont know if i did it right the tappets were sitting really low when i went to go adjust them and now that i adjust them they sit really high so i was wondering if i did it rite
Old Sep 18, 2005 | 11:37 PM
hondabuster's Avatar
Default valves
Were you on the correct tdc?
You could have been 360 degrees off on the timing mark on the crank. Were you able to wiggle the rockers with your fingers before adjustment, or were they too tight?
Old Sep 18, 2005 | 11:52 PM
Default valves
yes i was at tdc
they were to tight i couldnt get the feeler gauge threw so i adjusted them but noe they look so high then before they were adjusted
Old Sep 19, 2005 | 12:28 AM
Default valves
There are two tdc...one is the top of the compression stroke, and one is the top of the exhaust stroke. If they were tight when you started, it makes me believe you were on the wrong one. I think youre gonna have to go back and recheck them.
Old Sep 19, 2005 | 09:28 PM
Default valves
bump
Old Sep 19, 2005 | 09:32 PM
caliraptor's Avatar
Default valves
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
