2000 warrior need some help please!!
Old Sep 20, 2005 | 10:15 PM
10klt250r's Avatar
Default 2000 warrior need some help please!!
just got a 2000 warrior that had been sitting for a year. we drained the gas, cleaned the carb really good, and changed the oil, and then fired it up. it started fine and idles fine, but if you give it gas it just back fires real bad. and if you give it a lot of throttle it backfires and then dies. all while in neutral. have not tried to ride it because of this problem. any suggestions on where to start would be helpful, THANKS!
Old Sep 20, 2005 | 10:51 PM
zslate's Avatar
Parking brake can sometimes make it cut out, but I ain't sure about dying. Good luck to ya hope ya get it up and running!
Old Sep 20, 2005 | 11:03 PM
10klt250r's Avatar
ya we bypassed it but still no luck,....anyone one else got any ideas?
Old Sep 21, 2005 | 02:42 AM
2001Warrior430's Avatar
If you cleaned the carb then you probably removed the fuel \air screw..When you put it in did you snug it then back it out two full turns...also check your intake boot .....double check the accelerator pump is free....and that choke is not stuck ....hope one of those helps
Old Sep 21, 2005 | 01:58 PM
JBird227's Avatar
My warrior is doing the same thing, how do you bypass the ebrake?
Old Sep 21, 2005 | 07:35 PM
Taharnak's Avatar
Check the Carb boot that goes into the head, take a flash light and shine it on the peice that connects it to the cylinder head. Mine used to do that and I was riding one day and it died and couldnt start it by pull start (didnt have electric start) and we had to try and push start it a couple times. after I got up to the top end of gears, it would start to cut out too. Went home and looked at the carb and stuff.. the carb boot was torn. Mine still cuts out a little when im in neutral and give it more than 1/2 throttle of gas really fast. Hope this helps
Old Sep 25, 2005 | 02:53 PM
01warrior416's Avatar
on the clutch handle follow the line that goes from the e brake down into the harness, dicconnect the hwite harness, but leave connected into the clutch assembly...and tie up the line and tuck down into the frame, i did the same thing for the same problem
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
