warrior sprocket sizes???
Old Sep 26, 2005 | 12:18 AM
jasonswarrior85's Avatar
Default warrior sprocket sizes???
well my atv isnt at my house and im looking at new sprockets for front and back. does anyone know the stock teeth for both and what is a good setup for better acceleration. thanks for help
Old Sep 26, 2005 | 12:36 AM
warpigs's Avatar
Its been a while but I think its 13 front 40 rear.
Old Sep 26, 2005 | 12:37 AM
Sammich's Avatar
I was asking the same question a while ago. Do a search for "warrior sprocket" and there are already a bunch of posts/info on it
Old Sep 26, 2005 | 12:49 AM
Trxoutlawz's Avatar
Go here and you can use the machine specs to find the general info on your ride..
Great place for parts also..
Machine specs
Old Oct 24, 2005 | 02:34 PM
SmokeyZ's Avatar
i would greatly recommend 17 in tha front and 40 in tha rear get the front sprocket at vito's if you can't find it no where else
i topped my quad out at 70. and its accel is better than a blaster with a 14front and a 40rear which is pretty decent, all i have in it is a weisco piston,uni filter, head pipe, clutch kid,chain
Old Oct 24, 2005 | 08:49 PM
warriorguy22's Avatar
17 front? thats crazy! you must accelerate so slow, i didnt even know they made a 17 front for a warrior... the highest i would/will ever go on my warrior is a 15, and that was for highway riding. to get more acceleration, i would go with the 42 rear, i dont like the 13 front too much
Old Oct 24, 2005 | 11:01 PM
recon99's Avatar
17? you must be f*in nuts man. on a stock warrior I wouldn't go more that 1 tooth larger front sprocket, I have a 14/40 setup with 22 inch tires and I can go faster in 5th than I can in 6th because of how tall the gearing is. The way my gearing is setup I could probably hit about 72 before I hit the rev limiter in 6th if I had enough power. I'm thinking about switching to a 12 tooth so I can get some of my bottom end power back, 1 tooth is enough to make a noticable difference on a mostly stock quad.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Bernhard
Sep 25, 2015 12:45 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
