help with needle
Old Sep 26, 2005 | 12:24 AM
danny55's Avatar
Default help with needle
the needle assy on a 02 raptor, does anyone has a picture on how to install all the prat in the right order. i have a service manual that shows it one way and a c/d that shows it differant. what is the right way to do this[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 26, 2005 | 12:34 AM
thedieselkid's Avatar
This is how I put mine together, and its how they were together when I got it. first put the clip in the right slot then right below the needle there should be a white plastic washer or ring not sure what to call it, the the skinnier of the two metal washers below the plastic washer. the the fatter metal washer should go on top of the clip, then the little spring on top of that, and then the little plastic piece with the oring on it above that, and that is the piece holds the assy in place. and if you need any help then I can send you a picture.
Old Sep 26, 2005 | 12:43 AM
danny55's Avatar
with the white plistic spacer and washer is on top of the clip will that make it leaner ?
Old Sep 26, 2005 | 01:10 AM
not sure, but I wouldn't do it. if you want to change the needle position just change the slot that the clip is in.
Old Sep 26, 2005 | 02:47 AM
maddog56's Avatar
Yep, but that's not how you are supposed to adjust the jetting. There may be functional and clearance issues also when doing it that way.
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
