Warrior 350 suggested fuel grade
Old Sep 29, 2005 | 12:47 AM
Sammich's Avatar
Default Warrior 350 suggested fuel grade
Did a search, but nothing came up about the warrior. I have an 01 warrior and have run 87 octane fuel in it since i've had it. Are there are benefits to me running a higher octane fuel (93-94)?
I know you go higher octance when you have a high compression motor, but the manual doesn't even say what to specifically run. I know in cars, if you run premium when you you don't need to, you are just wasting money. What do you guys run in your warrior? But even if the higher octane isn't needed, wouldn't running the high grade fuel burn/clean the motor better (don't higher grade gasses have more/better chemicals that clean better than 87?)
BTW- I do notice my quad stuttering at high rpms sometimes, would this be due to it needed a higher octane, but this could also just be due to a dirty carb (I do plan on taking the carb off and cleaning it when I get a pipe/jet).
Old Sep 29, 2005 | 09:36 AM
3wheelerdude's Avatar
Dont waste your money, run 87 or 89 octane unless you are experiencing pinging OR have engine work done to it.
Old Sep 29, 2005 | 01:22 PM
keelam's Avatar
how bout a 2004 stock yfz450? My freind is running regular or 86 and he says it is fine. I told him what Happyrap told me, put in premium or 93 octane. any suggestions? BTW, what woudl happen if you put in 86 octane for a yfz450?
Old Sep 29, 2005 | 01:38 PM
If the owners manual says 87/89 is recommended, then dont go higher unless you mod it. Tell your friend to read is manual.
Too low octane will cause pinging (you will hear it) Its detonation before its time. Sometimes on old engine that build up carbon deposits, compression will increase and 87 octane will be the cause of pinging too. So instead of taking the head of and cleaning you can run higher octane and solve your problem.
Old Sep 29, 2005 | 05:44 PM
keelam's Avatar
thanks
Reactant
Mar 30, 2022 02:08 AM
Big bousse
Sep 26, 2015 10:42 AM
Aitch
Jul 21, 2015 09:40 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
Reactant
Jul 16, 2015 10:29 PM
