Flipped front wheels instead of using spacers
Old Oct 3, 2005 | 10:29 PM
  #21
mxgraphix's Avatar
Default Flipped front wheels instead of using spacers
Thanks for all of the input. I grinded the calipers off and flipped the wheels. It went fom the stock 43.3 inches to 48 inches wide. The difference in the handling is amazing. I don't have the rear spacers yet so the back end kicks out in sharp cornering...but thats the fun part. Makes doughnuts really easy too [img]i/expressions/face-icon-small-smile.gif[/img] I'd recommend it any day. My Raptor is no longer top heavy.
Old Oct 4, 2005 | 11:09 AM
  #22
ccgrady's Avatar
i tried flipping mine for a while and hated it. it made the front end hard to turn and put to much pressure on the shocks. it lasted for about a day and i put them back. i recommend you leave them in the stock position untill you cab afford aftermarket ones.
Old Oct 4, 2005 | 04:47 PM
  #23
mxgraphix's Avatar
I think I'll leave it for now...I'm kinda getting used to the better handling. If something tears up...I'll then have an excuse to get something bigger and better.[img]i/expressions/face-icon-small-smile.gif[/img]
ccgrady, I LOVE the graphics on your Raptor. I wanted them but my wife and I have different views on things like that. She can't see why I want to "mess up" a perfectly good machine.
Old Oct 4, 2005 | 08:15 PM
  #24
TheNadine's Avatar
Originally posted by: recon99
personally, I would do both at the same time. From my experiences when the front and rear are different widths the cornering is a little on the unstable side. If you were to do only one, I think the best would be to do the front first because I think that has a bigger impact on the cornering and stability, and you wouldn't have to worry about clipping trees with the rear tires because they stick out more.
He's right, before i got my axel on my Raptor with my aarms it got a little scary in turns, but my front end is 53 inchs also
Old Oct 4, 2005 | 09:03 PM
  #25
fordplay2's Avatar
I recomend getting some stronger tie rods. I had my front flipped untill my tie rod bent in half one day.
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
black_thunder
Jul 9, 2015 05:58 PM
