compression
Old Oct 2, 2005 | 08:54 PM
raptorider660's Avatar
Default compression
when i try to turn over my raptor there is to much compression then when i take the plug off it turns over perfectly wat could be the problem
Old Oct 3, 2005 | 09:45 PM
Default compression
bump
Old Oct 4, 2005 | 08:04 PM
2coky's Avatar
Default compression
are you using a hotcam? What happened to me they drilled the cam to deep for the compression release. The pin sticks out far while rotating and breaks off or is ground down leave the compression release not working. Call me we need to talk if your using a hotcam. john (734) 678-7418
Old Oct 4, 2005 | 08:33 PM
RacinJason's Avatar
Default compression
well do you have an aftermarket cam?
Have you replaced the one-way?
Old Oct 4, 2005 | 08:47 PM
2coky's Avatar
Default compression
yes, I had hotcam. No, there was no problem with the oneway. I built up araptor engjne for a friend and the pin broke off took out the oil pump and burn up the engine. Hotcam is aware of the problem. They changed the cam design. My engine wotn down the pin and the compression release worked less and less until the battery terminal melt while tring to crank it one time...
Old Oct 4, 2005 | 09:17 PM
enFORCER's Avatar
Default compression
Did you advance your timing? If so try setting it back a bit....
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
