clutch cable question on warrior
ok i posted b4 bout my clutch like slipping but come to find out my cable is really bound up like i have to use pliers and my foot to pull the cable once its of the bike ive tryed spraying wd40 and pulling it bacik and fourth but it stiill is pretty bound i think theres rust in it or sumthin but wat can i do to fix it besides by a new cable?
i took the cable off the quad but its hard to pull the cable ou of the sleeve but the cabl is in good condition and i need a way to make it easier to pull till i can get a new 1
the cable is not in good condition if it is hard to pull with pliers. the cable itself is probably frayed and causing it to bind up. It doesn't matter what the outside of the cable looks like. There's nothing you can do if the cable is bound up and lube doesnt work.
GregM
Mar 6, 2018 06:53 AM
