2002 Grizzly 660 - engine bog???
I have an 02 Grizzly 660. When it gets on a angle or in water the engine looses ALL power. It acts like the rev limmiter has kicked in but I am not in reverse? Can anyone tell me what to do or if you have had this problem please let me know how you fixed it. Thanks
Id check for a low float level, for the issue on hills, and look for connectors, below the water line(like on the front diff), which are shorting out. You could just unhook the connectors, and look to see if they are crusty or corrorded, and then shine them up, and pack them with dielectric grease, and rehook them up.
Thanks, I'll check all the connectors and get them corrosion free. How do I check the float level? I can take the carb bowl off no problem but what am I looking for as far as the float level being high or low? Thanks again. I've got to figure this out as it is leaving me in some really bad spots with no power when I really need it.
RedRancher
Oct 15, 2020 01:45 PM
