660 Timing
Old Oct 14, 2005 | 02:25 AM
2FAST4U69's Avatar
Default 660 Timing
Does advancing the timing on the 660 produce any gains? I saw a Degree key for it and I was wanderin if it was worth gettin.
Old Oct 14, 2005 | 01:20 PM
LivinInVegas's Avatar
Default 660 Timing
Unless you are into straight line all out dragging, I would'nt look at it unless that's what your into. There are better ways to get more gains then advancing timing.
Old Oct 14, 2005 | 07:08 PM
maddog56's Avatar
Default 660 Timing
Even then it hasnt proven beneficial. The only person I've seen say good things about a degree key on a raptor is warwagn and he's at a decent elevation so that may be a factor. I'm pretty sure that's the guy who has one, do a search and you'll find info on this.
Old Oct 14, 2005 | 09:01 PM
ItalianStallion's Avatar
Default 660 Timing
If your gonna go that far....ya might as well put in a stage 1 hotcam
Old Oct 14, 2005 | 10:15 PM
2FAST4U69's Avatar
Default 660 Timing
Yeah I havent heard anything on it that's why im asking. But yeah im probably gonna get a cam, when I hog out the motor a little bit. Hey stallion? I know your pretty deep into these machines, so I was wanderin if you could point me in the right direction on if I need to replace my rod, valves, valve springs, when I decide to do like a 686, or 690 kit? Also would I be better off with a stage 2 cam, if I do that, also what would you recomend for the carbs? Thanks for your time...
Scott
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
