Brake light switch help needed on Raptor
Old Oct 15, 2005 | 11:02 PM
Rob4092's Avatar
Default Brake light switch help needed on Raptor
I have a 2003 Raptor. The rear brake light is on all the time.
The brake light connection on my front brake lever is loose so the rear brake light stays on all the time.
If I push the connector wire into the brake lever, the brake light goes off. When I let it go, the connector backs off a bit and the light comes back on.
Can someone please tell me how to get this connector to stay tight into the brake lever?
Also, can anyone advise what plug I should be running in my Raptor and the gap?
Thanks a million!
Old Oct 16, 2005 | 04:11 PM
Rob4092's Avatar
Help please????
Old Oct 16, 2005 | 05:04 PM
sixsixT's Avatar
There's a plastic tab that sticks out from the switch that catches in the hole on the bottom of the perch.
Old Oct 16, 2005 | 08:16 PM
Rob4092's Avatar
Thanks for the response!
I keep my ATV's in Mexico so I cannot go to it and see what you are speaking of.
Can you please provide more info/description how to make the repair so I can print it and take it with me next week to fix the switch?
Thanks a million!
Old Oct 16, 2005 | 10:10 PM
sixsixT's Avatar
You just push the switch into the perch and the tab/barb snaps into the hole. If the tab is broke the you need a new switch.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
