Raptor 660 Clutch
Old Oct 21, 2005 | 01:36 PM
garyc660R's Avatar
Default Raptor 660 Clutch
Originally posted by: RacinJason
Look at the side case...there is a dot right where the shaft enters the case...the shaft itself also has a dot...these two dots need to lign up when the side cover is on...try it the first time without the gasket or any Yamabond so you see how it works...once you figure out how to line it all up put the gasket on and bolt it back together.
OK I may be of help. While looking at the clutch pack, make sure and turn the engagement arm to the rear of the quad (it sticks out of the clutch pack and does the actual engaging / disengaging). Put the cover on without the clutch actuator in the side cover. Now you need to put the clutch actuator in the clutch. A little jiggling and the actuator slides right into the engagement slots on the arm coming from the clutch. You must get the actuator in the position to where the dot on the actuator and the dot on the clutch cover line up (or come very close) when the clutch is ENGAGED. The clutch pack must have 2 fibers that are larger on inside diameter....these larger inside diameter fibers work in conjunction with the 2 metal sleeves that came from your original clutch.
Gary
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
