Blaster idling problem
Old Nov 8, 2005 | 06:27 AM
lethaface's Avatar
Default Blaster idling problem
Originally posted by: Ernie660R
I think your 32/1 Ratio is a little rich. Try 40/1 ratio!!
32/1 is pretty standard for a blaster if your using a castor based pre-mix such as the yamalube stuff..I use 40/1 when using klotz and 50/1 with amsoil..
Old Nov 8, 2005 | 07:42 AM
Izord's Avatar
Storj, you're thinking of the idle air screw. I'm talking about the slide-stop screw, On a Keihin carb it's how you adjust the mechanical end-point of the Big shiny thing that goes up and down in the carb throat.
Frisky2050
Apr 9, 2020 11:19 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
