removing t.o.r.s
ok, this is what you're talking about Sounds like if there was a problem with that, it would just kill the motor. Sounds like either you need to adjust the idle, or you got some crap in the carb. If adjusting idle doesn't make much of a difference, take carb apart again and make sure pilot circuit is clean.
