Warrior engine crank rod
How much slop should be in the engine rod. Mine has very little slop in it. should i replace it? And every time i change my oil i have metal shaveings in my oil. why is this? piston and cyilnder are fine.
well i dont know what you are calling slop. but on the metal shaving if you rebuild on your going to have some. you need to change you oil filter for about the firts 3 times after a built or just get a K&N like i have and just wash it out with diesel. but if your motor is not rebuilt i dont know. i had shaveings in mine the first 4 times i change my oil but i change it once a week after i built it now i change it once a month or sooner. it depends on how hard you ride
Ok thanks for the infor on the rod. But with the shavings there is lots! Every time i change the oil there are shavings in it. I called yamaha and they told me that the warrior does that and not to worrie about it??? i dont know.
as my starter clutch started going out and got worse there were more and more metal flakes in the filter. i haven't looked at the filter since the starter clutch was replaced, but i'm expecting less flakes than before
