BLASTER wiring questions/help!!!!
Old Nov 16, 2005 | 10:15 PM
FNAMOTOSPORTS's Avatar
Default BLASTER wiring questions/help!!!!
Hello all!! I’m in the need of some help!
I recently picked up a dirt cheap BLASTER. It runs great! Starts on the first or second kick, plenty of power, shifts like a dream!
Now for the fun part!
When I received this quad, all lighting was removed. Well, I’m wanting lights!
I ordered an “EBAY” front headlight assembly off of a B laster and still waiting on its arrival. I decided to take a look at the wiring under the front cover and see what she looks like. Everything looks intact, no cut wires, just a bunch of wires that are not connected!
The first thing I noticed that was not plugged into the main harness was the control unit (the little box with the roundish 3 pin connector). So with the quad running, plug the connector together…engine dies. Wont start with connector plugged in. unplug this control unit….engine fires right up! What does this control unit do? I probed around the other misc. wires that were unconnected and could not find a 12 volt source w/engine running? Any input? Thanks!
Old Nov 17, 2005 | 06:11 AM
lethaface's Avatar
here you go man..I was going to try and just copy and paste it in here for you but had a little trouble..This is the link to go to and then just go down to electrical and it will have everything you need ;-)
blaster manual
Old Nov 17, 2005 | 07:23 AM
Thanks!!!
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
DeFox500
Jul 26, 2015 06:32 PM
