warrior smoking question
Old Nov 25, 2005 | 04:38 PM
speedped79's Avatar
Default warrior smoking question
Originally posted by: hondabuster
Do a compression test, and youll have a good idea how bad it is. Its most likey worn out rings, but if the compression isnt real bad...and it runs good, id just put in a hotter plug, and keep running it .
will do ill be poting a video of me in the snow later today its still snowing out as i type
Old Nov 25, 2005 | 09:26 PM
speedped79's Avatar
http://media.putfile.com/me-playing-in-the-snow
Old Nov 25, 2005 | 10:48 PM
Sparky8370's Avatar
I'd do the comp test before just replacing piston & rings. If you're not losing too much power than it could just be valve seals or something. You'll lose some power burning oil regardless of the reason. Smell the oil, if it smells like gas it could be the rings. Also, if you haven't changed that oil in a while it could be real thin and would smell like gas if it's too thin to make a good seal. Fresh oil's cheap enough.
Old Nov 25, 2005 | 11:21 PM
yfx250's Avatar
ur burning oil check the valves because my cousins 4 wheeler smokes blue smoke and hid valves are messed up.
Old Nov 26, 2005 | 12:50 AM
  #15
speedped79's Avatar
im gonna check the valves one of these days we just got hammered wit snow 14 inches but regardless im putting in a je piston and evrything in spring
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
