Warrior/Raptor 350
Old Nov 27, 2005 | 11:09 PM
bberck's Avatar
Default Warrior/Raptor 350
I know the motor is basically the same but did they use the same frame.
Thanks
Old Nov 27, 2005 | 11:42 PM
Pelphrey's Avatar
this is a post off of yfm350central.com hope it helps
Yamaha Raptor/Warrior 350:
Raptor Specs are on top of the Warrior specs.
Engine
2005 Raptor 350
2004 Warrior
Bore x Stroke
83mm x 64.5mm
83 x 64.5mm
Carburetion
Mikuni 36mm BSR
Mikuni 36mm
Compression Ratio
9.2:1
9.2:1
Drive Train
2WD; Sealed O-Ring Chain
Ignition
DC - CDI
DC - CDI
Starting System
Electric
Electric
Transmission
6-Speed Manual Clutch w/ Reverse
Type
348cc 4-Stroke Single, Air Cooled, SOHC
348cc, 4-Stroke Single, Air Cooled, SOHC
Chassis
2005 Raptor 350
2004 Warrior
Brakes/Front
Dual Hydraulic Disc
Dual Hydraulic Disc
Brakes/Rear
Hydraulic Disc
Hydraulic Disc
Suspension/Front
Independent Double Wishbone, 7.9” w/ 5-way Preload Adjustment
Independent Double Wishbone, 7.9” travel w/ 5-way Preload Adjustment
Suspension/Rear
Swing Arm, 8.3”, and Threaded Preload Adjustment
Swing Arm, 7.9” travel with Rebound/Compression Adjuster & Threaded Preload Adjustment
Tires/Front
AT21x7-10
AT22 x 7-10
Tires/Rear
AT20x10-9
AT22 x 10-9
Dimensions
2005 Raptor 350
2004 Warrior
Dry Weight
375 Lbs
397 Lbs.
Fuel Capacity
2.4 Gallons
2.4 Gallons
Ground Clearance
4.5”
4.9”
L x W x H
69.7”x 43.1”x 42.5”
72.4” x 42.5” x 42.5”
Seat Height
32.3”
30.1”
Wheelbase
47.6”
47.2”
Other
2005 Raptor 350
2004 Warrior
Colors
Team Yamaha Blue/White; White/Red; Grey (Special Edition)
Lighting
Dual 30W Krypton Multi-reflector Headlights & 21/5W Brake light
Warranty
6 Month (Limited Factory Warranty)
MSRP
$4,999* Available from June 2004
$5,199* Available from August 2004 (Special Edition)
$4,699*
ag2560
Jul 14, 2012 06:00 PM
Kevin R.
May 25, 2009 06:09 PM
duster
Sport Quads
Jun 14, 2008 02:06 PM
kyledvor61
Jul 14, 2007 01:35 AM
4wheel4food
Sep 2, 2006 02:01 AM
