Cam chain problems
Old Dec 18, 2005 | 12:19 AM
caliraptor's Avatar
Default Cam chain problems
My mechanic is trying to get my motor back together and we are having problems getting the cam chain falling into the teeth on the bottom gear. Its right under the gear, just wont fall into the teeth. Mechanic thinks the chain is stretched and thats why it wont fall into place so we ordered a new one. Anyone have any idea if this could be the problem? What else should I replace? cam gear?
Old Dec 18, 2005 | 01:07 AM
CTracingraptor's Avatar
if it were me and i was having those problems, i would surely pull the case off and then pull the flywheel off and check, cuz it should IMMEDIATLEY line up and have no slack, do you have your cam chain adjuster removed???
Old Dec 18, 2005 | 02:25 AM
caliraptor's Avatar
no cam chain tensioner, just the bare cylinder with piston is installed. I think we might have to pull off the flywheel and stuff and check it out. When I did the piston/cam install the first time, I had no problem getting the chain back onto the gear. The damn chain just slides over the stupid gear [img]i/expressions/face-icon-small-mad.gif[/img]
Sjrpp
May 2, 2023 03:59 PM
Firefighter400
Oct 8, 2022 06:38 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
