Striped bolt
Old Dec 22, 2005 | 04:35 PM
YamiYFZ's Avatar
Default Striped bolt
I was tring to take my DG engine skidplate off my YFZ and i noticed the 2 back bolts had fallen out. From all the bashing the skid got pushed back a little and bent the front hex bolts a tinny bit making them very hard to get out. i got one out but accidenty stiped the head on the other one. how do i get it out.
Old Dec 22, 2005 | 08:08 PM
quad2xtreme's Avatar
I've had to use a dremel to cut into a bolt so I could just grab it with vise-grips to get it out. It helps to put a regular torch to heat it first too.
On other occasions, I've ground the whole head off. You can normally grab it at this point with vise-grips and get it out since the pressure has been relieved.
Old Dec 22, 2005 | 08:11 PM
Turtler's Avatar
There is a tool at Sears you can buy that basically cuts into the stripped head and will typically extract the bolt. The name of it slips my mind right now but the guys in the tool department will help you. You can cut a slot in the head and try a slotted screwdriver. Lube the thread to provide a little help.
Old Dec 22, 2005 | 08:17 PM
420rappy's Avatar
easy out (extractor) is what i call them and they have worked for me in the past
IdahoVinnie's Avatar
These "sockets" work extremely well. They work better than regular sockets. Snap-on Tools came out with them about 6 years ago, and many mechanics thought very highly of them.
These sockets grab on the outside of the hex portion of the bolt. No drilling is required, as with the conventional "easy outs".
YamiYFZ's Avatar
thanks. i went to lowes and got a easy out drill bit thing. it worked fine.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
johnny1982
Sep 13, 2015 07:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
