Grizz can't go 30+
Old Dec 28, 2005 | 02:08 AM
itsback's Avatar
Default Grizz can't go 30+
Originally posted by: hondabuster
Id be willing to bet, the weights have never been looked at or relubed. Or its been in water and mud, and the weights got dirty.
If the weights havent been looked at in a while, its time to lube them.
Wouldn't it do the same thing in low range though, or would the added torque multiplication compensate for it?
One more question before pulling the cover, do I need to drain the oil first? I like to get away with not draining it if I can.
Old Dec 28, 2005 | 12:27 PM
hondabuster's Avatar
The weights in the primary move, or more correctly are in balnce with the rpm vs the load. The secondary spring provides the feed back for primary position vs rpm. The engine has a much easier time in low, and the secondary allows the upshifting , even though theres resistance to the weights, moving out in their slots.
Dont skimp on the grease when you lube them, youre supposed to use 1/2 of the can of ultramatic grease, which is 1/2 lb, spread out equal to the weights.
No need to drain the oil,the pulleys are on the outside of the motor, under that big plastic cover. The weights are in the primary. It should be totally dry inside the cover, and maybe a bit dusty.
Theres a how to, on nyrocs site, and i believe texmudder has one too.
texmudders site
Old Dec 28, 2005 | 03:28 PM
itsback's Avatar
Thanks hondabuster for the link. Is there anything in there that I should/need to replace while it is apart? Since it does not mention anything I'm guessing that there's not any one time use only parts, but is there anything that should be changed even if there is not alot of wear showing?
Old Jan 18, 2006 | 04:40 PM
willi's Avatar
Is the motor under load when u r topped out in high gear or is does it seem liek you are in a low range? If it seems like u r in a low range it might be the cyntrifical pulley going bad.
Old Jan 19, 2006 | 10:19 AM
  #15
Hebs's Avatar
did you ever get it fixed??
did it sound different when you were in gear and WOT and when you were in neutral WOT? It sounds a lot like your belt is slipping.... Just the other week a buddy of mine's King quad had very similiar issues. Ended up that his belt had flipped over.
I've had similiar issues, but after pulling the plug and draining the water out of the belt chamber, (sorry brain fart, can't remember what the belt housing is actually called.) mine ran fine.... (it'll happen from time to time when mudding in a foot of water or more....)
Old Jan 19, 2006 | 01:10 PM
  #16
itsback's Avatar
When its in high gear it won't rev as high as it does in low and neutral. I decided to get a new belt just to see if it would help since it does have nearly 500 miles on it. After replacing the belt I only rode it once because I have no rear brakes (waiting on parts) but it did not have hardly any low end torque. It had just enough to get moving but that is it, it was just barely able to spin the tires on loose gravel.
I have a feeling the carb was not jetted right when it was rebuilt causing it to run to rich. Anyone know of an 02 sensor that would fit in the exhaust pipe without nearly blocking the whole thing off. I have a wideband 02 meter that will be going on my car when I put my built engine in, but the sensor is to close tothe same size as the pipe.
Old Jan 19, 2006 | 03:01 PM
  #17
Hebs's Avatar
my griz has 2000 miles on it, and I have yet to change the belt...
your problem is VERY weird.... It almost sounds like the clutch itself is slipping... I would call a few dealers and just talk to them about it and see what they have to say... a good one should be able to tell you the problem, or at least give you a list of possible causes....
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
