Blaster
Old Jan 6, 2006 | 08:31 AM
pyro1543's Avatar
Default Blaster
Yeah i have an 05 blaster that blew up and i bored it .60 over. when i hit six gear and just barlly crack the throttle im topped out. how many teeth should i drop to compesate for that or is there something else i can do.
i dont feel like blowing it up again.
thanks
Old Jan 6, 2006 | 11:04 AM
ShadyRascal's Avatar
Default Blaster
You can go to a 14 tooth primary, that along with the 40 tooth sprocket is as high as you can gear a Blaster from what I can find.
Old Jan 6, 2006 | 05:18 PM
pyro1543's Avatar
Default Blaster
im at 13 for the front and 40 in the back the 14 i bought for it the teeth were to big but what would be a good company to get the parts for it from????
Old Jan 6, 2006 | 05:58 PM
Default Blaster
Actually I just found you can go up to a 15 front although it's real close to the engine case which can present problems. and in the back you can get a 39 from a couple places. If you went to a 14 front you would notice some difference, and a lot of times you can pick this up from your local dealer cheaper than ordering one, in the 10 to 15 dollar range.
Old Jan 6, 2006 | 06:05 PM
warriorryder's Avatar
Default Blaster
go to www.projectblaster.com
Old Jan 6, 2006 | 11:30 PM
hondarulesinnc's Avatar
Default Blaster
Latter on down the road I would also look into getting 22 inch tires if you don't already, this would also help to gear you up a little. It would also help you get more ground clearance if you trail ride.
Old Jan 7, 2006 | 11:13 AM
fastblaster00's Avatar
Default Blaster
look on ebay. sometimes there a 15 tooth front
Old Feb 1, 2006 | 11:03 PM
pyro1543's Avatar
Default Blaster
Yeah i tried to go to a 14 but the teeth were to big so i dont know it mounted up but wouldnt spin due to size so im kinda hesitent about ebay i think ill just get one from a dealer
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
