fix it or lube it
Old Jan 14, 2006 | 08:46 AM
WindmillAtWork's Avatar
Default fix it or lube it
Hummm I don't know of any for ATV's specifically. I know there is a few for cars but I'm not sure if I would try it in a ATV or not. I think one is called Engine flush. If you use it I wouldn't run the engine to long with it in there. I would probable just try draining out what you have in there..put in yamalube ..run for a few miles...drain...put in fresh yamalube again and you should be ok.
Old Jan 14, 2006 | 12:28 PM
recon99's Avatar
Just drain the old oil, put some new motorcycle/atv oil in, ride it around for 10 or 15 minutes, then drain the oil, and put new oil and filter in. That should flush out 99.9% of the bad oil.
bmark0610
Sep 7, 2015 09:42 PM
79hugger
Aug 30, 2015 02:21 PM
user493
Aug 13, 2015 12:54 PM
pete/ny
Feb 28, 2000 09:16 PM
wallsenterprises
10
Nov 29, 1999 11:57 PM
