Raptor cutting out
Old Nov 6, 2000 | 06:19 PM
mtecate4g's Avatar
i've never had any problems with my raptor dying during a wheelie but that to me sounds like the float is adjusted to lean. as far as the jump kill is conserned mine also did that til i turned up my idle. most dealers dont set the idle at the right rpm when the set them up. it should be idling at 1450rpm. mine when i got it was idling at 800rpm. another thing that helped mine was putting a bigger pilot jet in it also. stock one is to small.
Old Nov 6, 2000 | 07:29 PM
2strokeDiehard's Avatar
I read in one of the first magazine articals on the raptor that they were having a problem with the thing loosing fuel in long wheelie situations, they were suspose to fix this problem before manufacturing! When i got mine thats the first thing i did was the longest wheelies i could to see if it was a problem, it wasnt on mine, my neighbor got one and his has no problems ether, I have had no problems with jumping ether! Both our bikes are fairly high in the Vin #s, I would check yours to see if its an early one, if so im sure your dealer could fix the problem for you. Hopfuly this helps you out!!
bmxatv10
Oct 14, 2022 06:23 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
black_thunder
Sep 22, 2015 07:59 PM
