ATV Brag Lists
A trend I have been seeing more and more is the guys on this and other forums posting every single little thing they add onto their quad, its rediculous... there are a couple of guys on this forum that seriously have this list that is almost a page long, ... LOOK AT ME!!! I HAVE A BUNCH OF STUFF DONE TO MY QUAD! OH PAY ATTENTION TO ME.... come on, some even list the quads they used to own... I have been riding ATVs since the days of the Honda 185s but I am not going to list all the ATVs I have owned...
Or maybe I will make up my own list... (with prices)
1988 Honda 250r FourtraxIMS 5.6 galllon fuel tank $189
Maier
Race front fenders $100
Stock-style front fenders $174
Rear fenders $178
UFO
Front fenders $128
BILLET PRODUCTS
BBR:
Gas cap $70
Casacade
Left engine side cover $315
Clutch cover insert $32
Water pump cover $90
Transmission dipstick $30
Gas cap $60
Chaparral/UMI
Stator cover $330
Clutch cover $40
Bar clamp $50
Shifter $90
Duncan Racing
Stator cover $330
Clutch cover $40
Bar clamp $50
Shifter $90
Graydon Proline
Gas tank cap $60
Rear reservoir cover $30
James Lucky
Kickstarter $125
Water pump cover $30
Brake pedal $155
Power Shifter shift lever $80
Lone Star Racing
Front wheel hubs $288
Rear wheel hubs $157
6-bolt sprocket hub $16
Nac's
Water pump cover $100
Clutch cover insert .$50
Mag cover $300
RPM
Left and right engine
cover set $400
Trinity Racing
Side cover set $450
White Brothers
Parking brake block off $11
PIPES AND SILENCERS
DG:
Xtreme nickel-plated pipes $315
National pipes $260
Chrome oval silencers $240
Type II silencers $180
DMC
Alien exhaust system $529
Duncan Racing/Paul Turner
Midrange pipes w/ silencers $459
Hi-Rev pipes w/ silencers $459
Fat Boy silencers $180
Fat Boy Quiet silencers $200
Dyno Port
2-into-1 w/
Big Core silencers $400
Nickel Plated 2-into-1 w/
Big Core silencers $450
Twin Pipes w/
Twin Pipes w/
Big Core silencers $500
FMF
Fatty $340
Gnarly $340
SST $430
Power Core II silencers $180
Turbine Core II
spark arrester $270
LRD
Adjustable pipes w/
silencers & jet kit $495
Pro Circuit
Platinum pipes $340
Factory Sound silencers $179
Spark arrester $270
PSI
Performance Pipe and
Silencer Set $595
Speedwerx
Thermal coated pipes $NA
Toomey
T5 Kit (pipes, silencers, air filter,
airbox vents, jetting) $480
T5/2:1 Airbox Kit (T5 kit plus
high flow filter system) $500
T5 Pro Rider Racekit (T5 2:1
kit plus Boyesen reeds and
machines pipe seals) $700
Trinity
Stainless steel pipes
with silencers $600
Steel pipes with silencers $400
GRAPHICS AND SEAT COVERS
Alba:
Graphic kit and seat cover $134
CEET
Original-look seat cover $50
Denton Racing
Graphic kit and seat cover $120
Duncan Racing
Graphic kit $70
Seat cover $75
Factory Effex
Graphic kit $55
Seat cover $69
FMF
Graphic kit & seat cover $150
Hi-Flite
Seat cover $59
Seat kit (foam and cover) $99
N-Style
Graphic kit and seat cover $140
One
Graphic kit and seat cover $149
Pro Circuit
Graphic kit and seat cover $150
SUSPENSION
Amp:
Amp Link chain
torque eliminator $159
Axis
Non-adjustable front $825
Non-adjustable rear $545
CT Racing
TCS front remote reservoir
shocks $750
TCS rear SCS modification $450
Elka
Remote reservoir front $675
Remote reservoir, fully
adjustable front......................$869
Piggy Back reservoir fully
adjustable rear $750
Ohlins
Adjustable, rebuildable
front shocks $790
front shocks $790
PEP:
Zero Preload front shocks $895
Standard front shocks $595
Progressive Suspension
Baja Magnum front shocks $234
Speedwerx
Titanium shock spring $489
Works Performance
AT Steelers, front $299
Duracross w/reservoir, front $489
Duracross w/reservoir, rear $449
Ultracross adjustable damping,
front $589-669
rear $549-649
WP:
Super Adjuster front $849
Super Adjuster rear $800
White Brothers/Dura Blue
standard width rear axle $297
White Brothers/Dura Blue 2"+2"
rear axle $369.95
White Brothers swingarm
skid plate $75
Works Performance A-T
Steelers $299
1994 Yamaha Banshee 350
Alba:
Direct Inject Nitrous
Oxide Kit $696
370cc Long Rod Kit from $1100
400cc Stroker from $1900
35mm Air Stryker carbs $370
34mm Keihin PJ carbs $259
Heavy Duty Clutch Kit w/springs,
plates & Hinson basket $310
Large capacity radiator $500
High Output (260-watt) Stator $250
Clear coolant hose kit $80
Delta Force reeds $260
Adjustable timing plate $100
Boyesen
Power Reeds $52
Pro Series Carbon Fiber Reeds $88
RAD Valves $260
CT Racing
Porting and head mod $450
Carbon Tech
Carbon Fiber Reeds $70
Duncan Racing
Pump gas head mod $65
Race gas head mod $150
Adjustable timing stator plate $100
Porting and head mods $490-550
National Engine Kit $2000
Eliminator Engine Kit $3450
Pyramid reed valves $199
Billet water pump shaft $80
Water pump drain cover $35
FMF:
Dual Mode AOF ignition $400
400cc Powervalve top end with
replaceable-dome heads $2000
Hinson
Billet clutch basket $250
James Lucky
High volume water pump
impeller $99
Large capacity radiator $400
2001 Yamaha Raptor
Hi-flow air filter $60
ATV Power Kit
(Hi-flow filter+jet kit) $124
L.A. Sleeve
409cc Big Bore
Monoblock Cylinder kit $1800
LRD:
TORS eliminator kit $76
Keihin PWK carburetors $460
Power-up stator/timing mod $100
National 350cc Top End Kit $1013
380cc Top End $1953
Complete Performance Engine
Kit w/pipes, carbs, & top end $3185
Pro Circuit
Porting and head mods $580
Pro Design
Changeable dome
Cool Heads $300
Pro-Flow intake $100
Trinity Racing
570cc Big Bore kit $4000
530cc Powervalve engine kit $4400
500cc Stroker Crank Kit .$3300
500cc Big Bore kit $3299
420cc Long Rod engine kit $1100
420cc regular rod engine kit $800
350 Pro MX/TT Kit $1700
350 Stage II $1000
350 Stage III $1000
350 Stage IV $1600
404 Stadium Kit $2200
Changeable dome heads $330
Programmable CDI $350
TwinAir
PowerFlow intake (large capacity
filter & leakproof flange) $80
Vito's
404cc Big Bore $470
Superstock pistons $220
Power pistons $200
Degree Key timing advancer $25
High Compression gasket kit $26
CHASSIS COMPONENTS
A&R:
2" Swingarm extension $120
J-Arm to A-arm kit $169
Extended A-arms $625
Adjustable A-arms $295
Chromoly Super Duty
tie-rods $299
Denton Racing
Camber adjustable A-arms $499
Steering damper $140
Swingarm w/carrier and
brake plate $739
Derisi
Footpeg extenders $36
Duncan Racing
Front braided steel brake line $39
Rear braided steel brake line $99
Eyeball Engineering
Swingarm $565
Chrome swingarm $715
Dura Blue
+2 Rear Axle $299
Wheel spacers $69
Rear hubs $109
James Lucky
Bronze A-arm bushings $90
JTM Products
4-1/2" Swingarm extension $179
Laeger's
Pro-Trax frame $2530
Swingarm $540
A-arms $578
Lone Star Racing
Outlaw frame $2310
Swingarm $524
+2 A-arms $650
Magnum
+2 A-arms $500
Tapered bearing carrier $230
Dual Row bearing carrier $180
Pivot Works
Chassis and wheel bearing
kits $30-$100
RAD:
Tapered axle bearing housing $250
Double Row Axle
bearing housing .$200
Titanium axle $800
Roll Design
Swingarm $995
Steering Stem $325
A-Arms $800
RPM:
Aluminum Axle $600
Steel Axle $600
Scotts
Adjustable steering damper $400
GUARDS
AC Racing:
Aluminum bumper $70
($85, polished)
Aluminum grab bar $48
($58, polished)
Standard nerf bars $149
($179, polished)
Cascade
Grille $95
Polished aluminum bumper $225
Brushed aluminum bumper $180
CT Racing:
Alloy bumper $70
Alloy grab bar $30
Duncan Racing
Chrome steel bumper $140
Engine skidplate $50
DG:
A-Arm guards $90
Center skidplate $130
Rear skid plate $100
Krome-Lite front bumper $135
Alloy front bumper $90
Alloy full chassis skidplate $130
Alloy grab bar $42
Alloy side frame guard $75
Alloy six-pack rack $125
Krome-Lite nerf bars $219
Alloy nerf bars $150
Graydon Proline
Center skidplate $85
Rear skidplate $90
Maier
Center skidplate $60
OMF:
Center skid plate $50
Chassis buard $60
Engine skidplate $45
Rear skidplate $80
PRM
Front bumper $85
Summit front bumper $105
A-arm guards $57
Rear skidplate ............$90
Pro-Tect
Aluminum center skidplate $95
Stainless steel rear skidplate $125
RAD Racing
Rear Skidplate $70
RPM:
Cyclone front hubs $360
Axle bearing carrier $269
White Brothers
Aluminum bumper $70
Aluminum nerf bars $150
Pro Series nerf bars $190
Rear skidplate $80
WB/IMS Pro pegs $240
Maier
Rear fenders $178
UFO
Front fenders $128
BILLET PRODUCTS
BBR:
Gas cap $70
Casacade
Gas cap $60
Chaparral/UMI
Stator cover $330
Clutch cover $40
Bar clamp $50
Shifter $90
Duncan Racing
Stator cover $330
Clutch cover $40
Bar clamp $50
Shifter $90
Graydon Proline
Gas tank cap $60
James Lucky
Kickstarter $125
Brake pedal $155
Lone Star Racing
Nac's
Mag cover $300
RPM
cover set $400
Trinity Racing
Side cover set $450
White Brothers
PIPES AND SILENCERS
DG:
National pipes $260
DMC
Dyno Port
2-into-1 w/
Twin Pipes w/
Twin Pipes w/
FMF
Fatty $340
Gnarly $340
SST $430
Turbine Core II
spark arrester $270
LRD
Adjustable pipes w/
Pro Circuit
Platinum pipes $340
Spark arrester $270
PSI
Silencer Set $595
Speedwerx
Toomey
Trinity
with silencers $600
Alba:
CEET
Denton Racing
Duncan Racing
Graphic kit $70
Seat cover $75
Factory Effex
Graphic kit $55
Seat cover $69
FMF
Hi-Flite
Seat cover $59
N-Style
One
Pro Circuit
SUSPENSION
Amp:
Amp Link chain
Axis
CT Racing
shocks $750
Elka
Ohlins
front shocks $790
front shocks $790
PEP:
Speedwerx
Works Performance
front $589-669
rear $549-649
WP:
rear axle $369.95
skid plate $75
Steelers $299
Alba:
Oxide Kit $696
Boyesen
Power Reeds $52
RAD Valves $260
CT Racing
Carbon Tech
Duncan Racing
FMF:
Hinson
James Lucky
impeller $99
2001 Yamaha Raptor
ATV Power Kit
L.A. Sleeve
409cc Big Bore
LRD:
380cc Top End $1953
Pro Circuit
Pro Design
Changeable dome
Cool Heads $300
Trinity Racing
350 Stage II $1000
350 Stage III $1000
350 Stage IV $1600
TwinAir
Vito's
404cc Big Bore $470
Power pistons $200
CHASSIS COMPONENTS
A&R:
Chromoly Super Duty
tie-rods $299
Denton Racing
brake plate $739
Derisi
Duncan Racing
Eyeball Engineering
Swingarm $565
Dura Blue
+2 Rear Axle $299
Wheel spacers $69
Rear hubs $109
James Lucky
JTM Products
Laeger's
Swingarm $540
A-arms $578
Lone Star Racing
Outlaw frame $2310
Swingarm $524
+2 A-arms $650
Magnum
+2 A-arms $500
Pivot Works
kits $30-$100
RAD:
Double Row Axle
Titanium axle $800
Roll Design
Swingarm $995
Steering Stem $325
A-Arms $800
RPM:
Aluminum Axle $600
Steel Axle $600
Scotts
GUARDS
AC Racing:
Aluminum bumper $70
($85, polished)
($58, polished)
($179, polished)
Cascade
Grille $95
CT Racing:
Alloy bumper $70
Alloy grab bar $30
Duncan Racing
DG:
A-Arm guards $90
Alloy grab bar $42
Graydon Proline
Rear skidplate $90
Maier
OMF:
Chassis buard $60
Rear skidplate $80
PRM
Front bumper $85
A-arm guards $57
Pro-Tect
RAD Racing
Rear Skidplate $70
RPM:
White Brothers
Aluminum bumper $70
Rear skidplate $80
Boy is that depressing, I think I would just cry if I had spent that much money. No way am I ever making a list of the money I have spent on anything, because I don't want to know. I'll list the major items if I want, or list my favorite toys in the garage, but I'll never ever risk having the wife see how much money I really spend [img]i/expressions/face-icon-small-wink.gif[/img].
So pretty much the whole point of this thread was to say that you dont like people that list everything they have done to their quads right? Or was it just a good way to list all of the things you have done so you wouldnt look like you were bragging?
Fordplay... read my post. I said "maybe I will make up my own list"
Also, DesertViper is the smart one here, he recognized immediately how silly it is to *list out* all the money (parts cost money) people spend on all the parts for their quads. Some people with the half page+ list of aftermarket parts is just weak.
Who cares about all the parts someone has listed in their signature... dont take up the forums with all that nonsense.
and your point is? It looks like you just want to have a good old brag about how much cash you have spent. I would personaly spend a bit more time in these forums and make constructive posts before I started spouting off.
