No Charge
Old Jan 21, 2006 | 08:52 AM
stevel63yami's Avatar
Default No Charge
Why won't my batterry charge up on a yami 200 4 wheeler?The electric start will work till the battery dies after a few days,,Any ideas???The lights all work,when the batterry is gone,but maybe there's a broken wire??ANY IDEAS??????Steve..
Old Jan 21, 2006 | 02:41 PM
fastquad02blaster's Avatar
Default No Charge
It could be a bad battery. The motorcycle and atv batteries don't last as long as car batteries. You can take it to an autoparts store and they can test it for you and tell you if it's bad or good.
Old Jan 21, 2006 | 05:41 PM
Default No Charge
Thanks my buddy,I'll do that for sure.I think it's the prblem.Do you know if it's normal for the bike to have no current between the pos and neg terminals when the battery is removed.Maybe there's a voltage regularor,that only sends current there when a battery is detected ???,,,Thanks again,,,Steve...
Old Jan 21, 2006 | 06:55 PM
1988TRX250R's Avatar
Default No Charge
you need to have voltage for there to be current, so if the battery is removed you'll have no current. w/ a fully charged battery, put a volt meter on the battery terminals and start the motor. you should see between 13.5 and 15 vdc. less means the charging system isn't working and needs to be diagnosed. more and your reg/rect is bad and overcharging the battery. sounds like you do have a charging problem by your description but start by making sure your battery is charged and have it load tested to verify battery is good.
Old Jan 21, 2006 | 09:22 PM
Default No Charge
Thanks guy,I never thought of that.So,I can test that in the morning.Much appreciated,,,Thatnks,,Steve....[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
zPuls3
Sep 12, 2015 08:54 AM
