01 raptor blues
Old Jan 23, 2006 | 06:49 PM
BIGBDVX400's Avatar
Default 01 raptor blues
I just put everything new in this engine,new jug,new piston,new oil pump, new white bros. cam,new water pump,new valves,new timing chain and tensioners,new clutch basket. It ran fine first time out,then with about 2 hours on engine it started to blow gaskets.First it was a side cover, now its the one under the jug. What could be the cause of this? Also does not want to put oil back into tank like it should.It is pumping but not filling oil tank like it should? Anyone got any ideas? Help a brother out!
BIG B
Old Jan 23, 2006 | 06:52 PM
BIGBDVX400's Avatar
By the way I used moose brand gaskets.
BIG B
Old Jan 23, 2006 | 10:20 PM
quadbart's Avatar
Hmm, Why all those parts?
What happened that you needed to do such a rebuild?
Well, if your in the market, I have an 01 motor sitting in my garage im looking to sell.
Old Jan 23, 2006 | 11:14 PM
RaptorRRC's Avatar
what do you want for that motor quadbart? Pm me if you want
Old Jan 24, 2006 | 01:21 AM
quadbart's Avatar
My pms are locked
email me QuadBart@aol.com
Old Jan 24, 2006 | 01:33 AM
BC660's Avatar
Big B is working on my motor. It dropped a value at about 95 mph had a 15 tooth on the motor and a 40 on the rear. Completely distroyed the head and piston filled the motor full of pieces of piston. By the way how much do you want for the 01 raptor motor? Let me know I need a spare just got into arena cross.
Old Jan 24, 2006 | 01:51 AM
quadbart's Avatar
Like I said, email me QuadBart@aol.com
Old Jan 24, 2006 | 02:29 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Check to make sure your crankcase vent is not plugged or restricted. Unless you have really excessive blowby the rings that is the most likely problem.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
