--- banshee start problem - cleaned the carbs --- changed the plugs --- cleaned the filter --- please help
Old Jan 24, 2006 | 12:47 AM
HomeBoy15's Avatar
Default --- banshee start problem - cleaned the carbs --- changed the plugs --- cleaned the filter --- please help
normal compression
it takes 50-60 kicks to start
tryied polling the choke 1. full choke 2. half choke 3. off choke
please help
Old Jan 24, 2006 | 01:07 AM
HomeBoy15's Avatar
btw 150 psi in each hole
Old Jan 24, 2006 | 01:39 AM
buck183's Avatar
Check for spark. If all is good there start with fuel. It's usually one of those two.
Buck
Old Jan 24, 2006 | 08:53 AM
ZillaRider02's Avatar
Be sure to check the reeds also.
Old Jan 24, 2006 | 12:44 PM
zorro700's Avatar
Check the small tube that goes between the carbs. Not the big one on top but there is one below that, that connects the actual chokes together. To be sure just replace it. If it is sucking air you actually aren't choking the engine and will make it VERY hard to start.......trust me.
Old Jan 24, 2006 | 06:31 PM
GITRDUN's Avatar
Dont kick your self to death. You must be in better shape than i am if you can kick that thing 50 times. Just give it a shot of starter fluid right down the throat and see if it fires up. If theres spark it will fire in a kick or two. If it runs for a few seconds on the starter fluid then dies you arent getting any gas out of the carbs.
Old Aug 2, 2006 | 05:09 AM
Bansheednr's Avatar
Be sure to check your reeds to see if they are cracked cause this has happened to me before. So i replaced them and it started up.
'91 Banshee
Toomey T5
382cc Pistons
K&N filters
Boost Bottle
Jetted by Trinity Racing
'88 YZ 80 bored to 87cc
DG exhaust system
Old Aug 2, 2006 | 09:31 AM
kawiking's Avatar
reeds,coil-wires(spark),carb tubes. make sure on switch is on and gas on-sorry it happens,ive done it. have you tried to pull start it??
Old Aug 2, 2006 | 11:19 AM
MDS2106's Avatar
Air/fuel screws could be out of adjustment.Also to small of size on pilot jets can cause starting problems.
Old Aug 2, 2006 | 05:10 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Make sure your carb slides are in the rite carb. The dome cut side of the slide should be facing out toward the filter.
