warrior clutch
Old Feb 5, 2006 | 11:36 AM
madmad's Avatar
Default warrior clutch
Hello,
I was wandering if anything could be done about the stiffness in the clutch on my wifes warrior? Could the springs be changed to a spring with less tension? The current springs have a yellow paint on them. I have already replaced the cable and this morning started working on the clutch. Any help or comments would be appreciated.
Old Feb 5, 2006 | 12:09 PM
warriorboy22's Avatar
if you mean its hard to pull the clutch in lube the cable
Old Feb 5, 2006 | 12:42 PM
recon99's Avatar
The cable and clutch perch are the biggest factors in the pull. I have a Motion Pro lever and perch with bearings at the pivot point, and a Motion Pro Terminator cable, and the clutch pull is easy and smooth as silk, even with the stiffer springs from my EBC clutch kit. If you made the clutch springs any softer than the factory ones you would have problems with excessive slipping and accelerated clutch wear. My clutch pull was extremely stiff with the stock cable and perch, but you remove a lot of friction from the mix with a high quality perch, lever, and cable. I spent about $50 on all 3 parts.
Old Feb 5, 2006 | 01:51 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
how muc hwas your EBC?
also you could get a hydraulic clutch...
Old Feb 5, 2006 | 01:57 PM
recon99's Avatar
the ebc was 65 plus shipping on RMATV
Old Feb 5, 2006 | 03:11 PM
madmad's Avatar
Thanks for the replys, I bought this warrior used and dont know the history, or if it even has a factory clutch in it, and so far I have broken two clutch holding tools trying to get the nut loose Where did you get your lever and cable?
Old Feb 5, 2006 | 03:16 PM
recon99's Avatar
Did you try using an impact wrench to get the clutch boss nut off? That works much better than the clutch holding tool and a ratchet.
I bought my parts from the local powersports shop. The Motion Pro Terminator cable is about $17 most places, which is pretty good for the best cable on the market right now. You can get an ez-pull clutch lever and perch on ebay for around $30 right now. The only complication with the clutch perch is that you will lose the operation of the parking brake(most of the time they don't work anyways though, and cause more trouble than it's worth)
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
