Wolverine Throttle- Broke it
Old Mar 9, 2006 | 01:59 AM
RhinoRaptor's Avatar
Default Wolverine Throttle- Broke it
I rolled my Wolverine today and broke off the thumb throttle lever. Does anyone know is the is the throttle for the Wolerine specific to that model or is it interchangable with any other models such as a warrior?
If I crack the thumb lever can I just replace that lever somehow or do I need to buy the whole throttle mechanism?
Thanks
Old Mar 9, 2006 | 02:25 AM
recon99's Avatar
Same as warrior, probably same as some other models too. Look up the part for both models you are comparing at a parts finder like this one, add the part for each one to the cart, and see if they are the same part number. If the part numbers match (quantity will become 2 when you add the 2nd one) they're interchangable.
Old Mar 9, 2006 | 11:05 AM
Thanks for the help, that answered my question.
It looks like the Warrior. Raptor, Kodiak use the same Throttle lever but the Actual Assembly has a different part #.
The Part #'s on the Raptor and Kodiak has a Throttle Assembly part # of 4kb-26250-00-00, the Wolverine has a part # of 4kb-26250-10-00. They both have the same price, the only difference in the part # is the 10 at the end. Does anyone who know Yamaha part #'s know what the difference may be. The reason I ask I can get a Raptor Throttle Lever Assy on ebay for less than the price of a new lever and without the work of tearing the Assembly a part.
Thanks
Old Mar 9, 2006 | 11:40 AM
recon99's Avatar
It might have a different amount of pull, since the raptor has dual carburetors, and the throttle assembly just looks a little different. The worst case scenario, you would just have to take them both apart and swap the levers, which would only take a couple minutes.
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
panicmanic
Sep 28, 2015 12:59 PM
nastyblaster100
Sep 13, 2015 01:19 PM
