painting
Old Mar 16, 2006 | 12:07 PM
Tyayo420batavia's Avatar
Default painting
just wondering, when you paint the frame of a wheeler, do you have to powdercoat or powecoat it whatever its called? or can you just spray it on with a compressor?
Old Mar 16, 2006 | 12:17 PM
ThrashAndCrash's Avatar
Default painting
You can either paint it, or powdercoat it. The powder coating is a dry chemical that is sprayed on, then baked. Powdercoating is a tough kina plastic coating.
Old Mar 16, 2006 | 03:26 PM
recon99's Avatar
Default painting
The powdercoating will look good forever. Paint will wear out, chip, and peel eventually, but when it's done right it will last a while. If you're willing to spend the money, powdercoating is the best way to go.
Old Mar 16, 2006 | 06:33 PM
KRAZYKRACKER's Avatar
Default painting
powdercoat
Old Mar 16, 2006 | 08:01 PM
Ds650RaCeR's Avatar
Default painting
either way you go you will have to get ur frame sand blasted... i have painted plenty of frames.. as long as you prep them right and put the right amount of coats on the frame.. it should turn out really well and last a good while..
Old Mar 22, 2006 | 04:01 PM
okbeast's Avatar
Default painting
Powdercoat would be your best bet, but don't think you can just get it powdercoated and forget about it. It will still need maintenance, especially around places that get rubbed on or it will start to rust.
nachop
Feb 14, 2018 06:57 PM
95wolv
Jul 21, 2015 12:25 PM
Reactant
Jul 16, 2015 10:29 PM
hiofcer
Oct 5, 2000 04:43 AM
