Grizzly diff drain plug
Old Mar 30, 2006 | 04:11 PM
Doodle's Avatar
Default Grizzly diff drain plug
I was going to change my rear differential fluid last night and I tried to loosen the plug and I couldn't budge it. I mean I tried with all my might and nothing. I even bent the allen wrench I was using. I don't think I had quite the right size wrench though because I think it was standard size since there was a slight amount of play. Anybody have an idea of what metric size allen wrench this nut takes? I got the front one off no problem. I don't know if they lock-tited it from the factory or what? Anyone else ever had this problem?
Old Mar 30, 2006 | 09:47 PM
OGGYDOGGY's Avatar
Stripped my front diff. drain plug, got a bolt from dealer 10 mil. I think and there was enough threads left up inside so I used it and it works fine . The stock plug threads are too short.
Old Mar 30, 2006 | 11:37 PM
MuddyGrizzly's Avatar
tap with hammer (fairly hard) first then try with allen wrench (this works 90% of the time) or use a needle nose vise grip pliers ! (tap first !!)
Old Mar 31, 2006 | 09:24 PM
Vakero's Avatar
Purchase a metric allen key socket set and you will have no problems removing the plug.
Old Mar 31, 2006 | 09:26 PM
Vakero's Avatar
Also, Lefty loosey,,Righty tighty.
There is no LocTite on those threads nor should there ever be.
greg74
Sep 10, 2019 03:03 PM
SDR-II
Sep 29, 2015 01:06 AM
Jul 28, 2015 12:12 PM
Captjay
Jul 23, 2015 12:33 PM
Shifts
Jul 3, 2015 07:59 AM
