blaster help
Old Apr 8, 2006 | 06:07 PM
Fergy69's Avatar
Default blaster help
i just put a FMF silencer on with my dg header and it ran good for a while but then started bogging out and then after a while it just wouldnt start so i think i blew the piston rings or piston and after i get that goin wat size jet should i put in it i think that is why it was running bad
Old Apr 8, 2006 | 08:39 PM
recon99's Avatar
Did you check the spark plug? If you didn't, try putting a new one in.
Old Apr 8, 2006 | 10:37 PM
BourneTrailBlazer250's Avatar
If you put on a new pipe and silencer, you need to rejet so your quad doesn't run too lean.
Old Apr 9, 2006 | 01:25 AM
lethaface's Avatar
there is alot of factors like elevation and tempature, but i would try a 280, do a plug chop and see where your at..Did you buy your pipe new? if so it should have came with some jets(most pipe companies send them, not sure about fmf though)..But like the above stated do not ride it until you rejet becuase your probably riding very lean right now..A lean condition will kill a top end almost as fast as a air leak..
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
