Gas Life
Gas can get stale, I think you're right on the line where it can start to go bad. It partially depends on how well your cans were sealed, if it's a perfect airtight seal than you should be ok, but if the cans had any kind of air leaks I don't think i'd use it for anything other than a lawnmower.
Sounds like a good idea, but before I went and mixed 50/50 with all 3 cans i'd just do about half a gallon of old and new together and see how it works, if your old gas got water in it from condensation you could end up with twice as much bad gas if you mixed it all 50/50 before you test it.
